Όλα είναι σαφή! Δε χρειάζεται παραπάνω ψάξιμο και κανένα "αστυνομικό όργανο" δε μπορεί να πράξει κατα το δοκούν, ή να θεσπίσει δικό του κανόνα!
ECE 22.05 Helmet Standard:
ECE stands for “Economic Commission for Europe,” which was created under a United Nations agreement in 1958. The 22.05 part refers to the specific regulation that the standards for testing are described in.
The ECE standard, which is accepted in 47 countries, is similar to the DOT standard in several ways, for example: like the DOT standard, peripheral vision through an arc of 105° from the helmet midline is required. Also, environmental conditioning of helmets to be tested is required similar to the DOT standard and certain labeling requirements apply, as well.
Impact absorption testing is performed in a manner very similar to the DOT standard, involving a drop test from a fixed height on a steel anvil with a headform fitted inside to measure the energy transmitted. Peak acceleration energy at the headform allowed to pass the test is 275 G. Impact absorption and rotational forces are also tested at points where any surfaces or parts project from the shell of the helmet.
The retention system is tested with a free-fall drop test of a 10 kg (22.0 lb) weight from a height of .75m (29.5 in.) attached to the fastened chin strap. No more than 35mm (1.37 in.) displacement of the attachment point is allowed.
The chin strap buckle system is also tested for slippage under load, and the strap material itself is tested for abrasion resistance and tension failure load (which cannot be less than 3kN or 674.4 lb.). There are also tests for ease of release and durability of quick-release buckle systems.
There are some areas where the DOT and ECE standards differ, for example: The surface of the helmet is tested for abrasion resistance—but in this test the performance standard requires that the helmet surface either shear away or allow the test surface to slip past the helmet. This is to minimize the amount of twisting force the helmet would transmit to the wearer’s head and neck. Projections from the helmet (snaps, rivets, etc.) may not exceed 2 mm.
Another test assesses the rigidity of the shell of the helmet by measuring the deformation of the helmet shell when progressively more load is applied up to 630 Newtons (141.6 lb.).
In addition to these areas, ECE 22.05 includes performance for the visor on a helmet, if it is an integral part of the helmet. DOT provides standards for visors and other eye-protection gear in a separate standard referred to as VESC 8 (Vehicle Equipment Safety Commission). The ECE standards do not include a test for penetration resistance.
The ECE standard includes requirements for retroreflective materials that may apply in specific member countries.
Unlike the DOT system, where the product is not subject to third-party testing prior to sale, the ECE system required batch sampling when production begins, submission of up to 50 sample helmets/visors to a designated laboratory working for the government that uses the ECE standards under the United Nations agreement and verification of quality control during on-going production.
The ECE standard specifies which type or configuration of helmet the approval applies to, using the following codes: “J” if the helmet does not have a lower face cover, “P” if the helmet has a protective lower face cover, or “NP” if the helmet has a non-protective lower face cover, (stated as ECE 22.05J, ECE 22.05P or ECE 22.05NP).
Πουθενά δε λέει για full face ή άλλο τύπο κράνους.
Αντιθέτως αναφέρει τα standards που πρέπει να πληροί κάθε κράνος, σε σχέση με την αντοχή σε χτυπήματα, πεσίματα, G κλπ. Επίσης τις προδιαγραφές της ζελατίνας (όταν αποτελεί μέρος του κράνους, γιατί υπάρχουν και κράνη χωρίς....
EDIT: - Φάουλ η μη ύπαρξη μετάφρασης του κανονισμού στα Ελληνικά στο σχετικό νόμο
-Καλύπτεται το παραπάνω φάουλ, με την έγκριση τύπου για την πώληση στην Ελληνική αγορά του κάθε κράνους. Κοινώς, "έχει ταμπέλα ECE"? Είναι ΟΚ!
